Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am creating a design that requires left and right mirrored components and I want to ensure that I'm following the correct workflow. I searched the archives for a similar question but found nothing like this.
The design is for some inlet adapters for mounting throttle bodies onto an existing engine manifold. This is all work-in-progress as I learn how to use F360.
This is what I did:
- Created the left adapter as a new design.
- In A360 created a copy of the design and renamed it as right adapter
- Created a mirror of the original body then removed the original body which left me with the component I wanted.
- Inserted the left adapter (blue item) as shown in the screenshot.
- Tried to insert the right adapter, but it was not possible...
Fusion 360 did not allow me to insert the component as it was a clone of an existing part:
So my idea of the correct workflow does not match Fusion 360's expected workflow.
So how should I do this?
Thanks for any answers,
Ian
