- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hiya! I posted yesterday about aligning components and I received the advice that I needed to use joints rather than using the move command. I just wanted to make sure on this next part - I'm assuming these joints are going to be primarily driven by the level of detail of my sketches yes? For example, if I want to put a wall stud 24" center along a rail, the sketch of the rail must have some sketch geometry at 24" center so that I can precisely place the rigid joint for the stud. Without that sketch geometry there is no way to place the joint at precisely 24" center....am I on the right track here?
Secondly, I am making a flat for a musical show and I have built one 8'x10' section. I want to duplicate that section. I selected all of the components and did copy, but found no paste option. So I tried mirroring it but things went wonky and ultimately crashed the program. I have included a screen cast of it. Am I going about this the wrong way?
Thanks in advance!
