Wont let me chamfer
Wont let me chamfer
ToolFool360
Wont let me chamfer
ToolFool360
So when i try the chamfer and disable tangent chain it still gives me a warning, how can i stop this?
patilsm
Hi @ToolFool360,
Thanks for your post.
I have checked your attached image, where you are trying to chamfer on edge where you very small depth which very small that chamfer size.
This message gets disabled once you reduce your chamfer size(Distance).
Sagar
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
Thank you @ToolFool360 For Sharing your problem with the community.
I think you should go for separate chamfer or use a tangent chain you will get the desired output which you want.
Hope the above information helps you!
Bhavesh Raghwani
ToolFool360
But heres the ting, it will let me do it on different angles such as but not this one. I have done it with a bigger length but this time it doest let me.
