WIP Pander D model 1924
Hello Fusionistas,
In response to show some of the project we, a group of enthusiastic volunteers in the Netherlands are working on I started this topic.
We are planning to build a replica of a small airplane from the year 1924 called Pander type D. Wing span 8.00 m, Fuselage length 4.95 m.
A while ago the historical research began and using the collected data it is my task to make drawings from it.
The workflow is as follows:
- In Illustrator I made sketches scale 1:1 from the only photograph in existence of wing rib #3.
- Next all 10 ribs were drawn in Illustrator using the collected information.
- Next I drew a rectangle around every rib positioned at the same distance and angle from the highest rib point and of the same size. The highest point of every rib line up with each other.
- After this the rib drawings were saved as separate pdf files and in Photoshop saved as jpg, quality 12, 150 dpi.
- In Fusion 360 I saved the first file as WingRib2, having the largest contour.
- Using Attached Canvas the first WingRib2.jpg was placed, horizontally flipped and calibrated. The center of the wing spars are 750 mm apart.
- Using Spline and Line I drew the contour so in the copy's of the component the contours would have the same amount of vertexes.
- The file was saved and saved as copy to create a set of wing rib files.
- At the end I saved a new file giving it the name Wing and inserted all the other files in it.
The result so far is shown here.
There is more to come in the future. Hope you like this WIP.
Frans Hessels
