Why the need to constrain with collinear when making a line on X-axis
- Mute
- Permalink
- Report
Hi and thanks for your help.
I'm following some 2D sketching tutorials.
Is there something in my settings I need to change? Everything was drawn with a line. The blue line at the bottom. I drew it directly on the X-axis. Why is it not attached to the X-axis like the black line of 100mm to the left of it which I started from the origin?
I had to use Collinear constrain with the 100mm to the left.
Thanks.
Is there something in my settings I need to change? Everything was drawn with a line. The blue line at the bottom ... I drew it directly on the X-axis. Why is it not attached to the X-axis like the black line of 100mm to the left of it which I started from the origin?
Thanks.
