New to 3D modeling so still learning and caught on this one. This 3D model is not mine. I found the model online for 3D printing. I was adjusting some things before I printed but when I sketch a circle to extrude/press pull only half of it actually shows pressed. I have both halves of the circle selected too and when I do the press it looks like it works but the results look different. See attached
If you look on the opposite end you'll see a rectangle cut out I did that worked fine.
Solved by etfrench. Go to Solution.
The two faces on the circle end are not on the same plane. You can either do a two direction extrude or delete the lower right triangular face.
ETFrench
Thank you. Is there a indication I can look for that would have shown me it's not on same plane? I deleted it. Not sure why it was there actually.
The clue was the thin piece left in the circle after extruding. I don't know of a good way to ensure the faces are coplanar.
ETFrench
