- Mute
- Permalink
- Report
I have designed an enclosure for an electronics assembly. When doing the final assembly drawing I noticed that the boards are not centered vertically, they are about 27 mils too high.
This assembly was made from components. The board on the left was imported, its holes projected to a sketch then used to cut the lid. Then the fasteners and boards were joined to the center of the holes. So, there's a lot of stuff hanging on these holes.
I have tried to move the holes in the lid to no effect. Then I tried to bump the board up to no effect.
How can I use Fusion 360 to see what needs to be changed in order to see this issue corrected? Obviously something is constraining the movement. Ideally I would have started by positioning the board exactly in the middle of the lid, but I could not see how to do that.
Any help appreciated. Here's hoping I don't have to start from scratch...
