Why feature editing is not available
Hi Guys
I start working on a model and after making components from bodies I found that I cant edit any feature. Would I know why its not available???
daniel_lyall
You are in Direct Modeling (DM) in DM you don't have the same editing ability as you do when you are useing the timeline.
If you have a look at this vid it goes over some of what you need to know. https://www.youtube.com/watch?v=AKUv1VIexx4
Also if you have a look in the learn section there is a lot of info in there that you need to know http://help.autodesk.com/view/fusion360/ENU/
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
I am working in parametric mode not in direct modeling mode.
mroek
@Anonymous:
You are in direct modelling mode, so features can't be edited. If you want to edit existing features, you need to turn on the timeline, by right-clicking on the root component and activate "Capture design history". After that, any new features you create can be edited afterwards, but the features/operations you did while in direct modelling mode will disappear.
If you want to use the timeline, please ensure that capturing design history is enabled whenever you start a new design. The default for this can be found under Preferences/General/Design, where there is a drop-down list that lets you choose the default behaviour.
mroek
@Anonymous
That's just the default setting. It can also be turned on or off on the fly, and you have turned it off, most likely without realizing it.
Oh
Got it. Bundle of thanks.
