Why doesn't this arc constrain?
bryancostanichwlabs
Message 1 of 10
bryancostanichwlabs
this is something that's bothered me for some time. fusion is so random with what is constrained and what is not. check out these arcs. All drawn as centerpoint + two point arcs. Note the top two were happily constrained with just a centerpoint and the implicit intersection nodes.
the bottom, however, doesn't constrain (remains blue), even if i explicitly add points at the intersection nodes. all those node points are constrained, too, yeah, because they're black?
This has driven me nuts for years, and I'd like to finally understand it.
Replies (9)
Message 2 of 10
g-andresen
This does not occur for me.
Please share the file for analysis.
File > export > save as f3d on local drive  > attach to post.
günther
Message 3 of 10
etfrench
It works fine on my Windows 11 machine.  Share your file and/or make a video of your workflow.
ETFrench
Message 4 of 10
bryancostanichwlabs
file attached.
Message 5 of 10
jhackney1972
Your Arc center is missing a Coincident constraint to the circle center point.  Simply sketching the arc on center sometimes does not automatically apply the need sketch constraint.
John Hackney, Retired
Message 6 of 10
bryancostanichwlabs
interesting. is that true even if i explicitly place a node there?
honestly, that looks like a bug.
Message 7 of 10
TheCADWhisperer
@bryancostanichwlabs
Whenever geometry doesn't show as constrained - do the logical thing, click and drag it.
That should show the missing constraint.
BTW - you are working wayyy too hard in creating your geometry.  There is a better way.
Message 8 of 10
laughingcreek
@bryancostanichwlabs wrote:....honestly, that looks like a bug.
looks like a bug to me also.
when that square glyph shows up at the cursor, it should mean it is going to apply a constraint.  on the nodes that have circles it isn't applying the constraint.  seems like something about this is confusing the sketcher.  @Phil.E ?
Message 9 of 10
Phil.E
@laughingcreek Thanks. Looks like something for the sketch team.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 10 of 10
sameer_babarNJS6C
Sorry for the inconvenience caused & Thank you for sharing the files. I can reproduce the issue at our end. Our team will analyse it further more.
We have logged an issue FUS-191194 for it & we are looking for the solution .
Sameer Babar.
Autodesk Fusion Team
