Why does prismatic conversion almost never works?
lkeays
lkeays
I paid a full license pretty much solely to be able to use prismatic conversion of stl files.  I don't think I have ever been able to convert a single one successfully so far (20+ different models).  Watched tons of videos.  What am I missing?
  1. I place, center and set units of measures on stl file
  2. I Generate Face groups (fast or accurate - tried both)
  3. Convert Mesh, prismatic, and... fails.  Either completely, or I get a weird model.
I mean I get the point that it's it's a cube, it will work, but that's something I can re-make.  I am kind of expecting it to work on complex models - otherwise what's the point?  Or am I doing it wrong?
Original STL
Fast / Accurate Face Groups
Failed result (fast / accurate)
I've attached the stl model.  A
Any help is appreciated.  Thanks.
lkeays
I will answer myself as I got it to work....  When converting to face groups, using accurate, I change the precision to 10x less.  From 0.001 mm  to 0.01 mm.  It worked.
Edit: at 0.01mm, it still didn't generate a body.  There were "holes" left.  So I tried the face groups again with an accuracy of 0.005 and miracle.  I have a workable body.  Thanks.
TheCADWhisperer
Are you editing Face Groups too?
lkeays
I wasn't editing them.
youngro8
Same question!! Its a useless feature, has literally never worked for me and also the main reason I decided to subscribe.  I guess its on me for not researching it enough, I'm sure its real function is to just lure people in so I guess its working.
TrippyLighting
It works on relatively simple prismatic (mechanical) geometry, that was generated by CAD software. Such mesh files still exhibit some form of topology recognizable by these algorithms.
But even then, once a part has many blended fillets, this often fails to produce useful results.
It does not work well with scanned meshes as those do not have any topology.
