Why does my post not align with the hole?
warrenbuc
warrenbuc
I'm making a case for a PCB and created standoffs for the PCB to mount to with a hole for a M2.5 mm screw to attach it. My sketch shows all 4 holes are aligned with the PCB but when I use Joint to align the PCB to the upper right support.  3 of the 4 support line up perfectly but one doesn't.  Any idea on what I did wrong?
jhackney1972
When you placed that one hole, you forgot to select the edge of the round to center the placement of the hole.  Animate GIF will show this.
John Hackney, Retired
