why canvases are inserted into assemblies and not into components?
essamZLPJD
essamZLPJD
Community Visitor
Community Visitor
I had a component under an assembly (top node) and I made sure that the component is active. When I inserted a canvas, it went into the top level assembly and not under the component. why is that?
TheCADWhisperer
Did you select a face or plane in the active component, or did you select a face or plane at some other level in the assembly?
And also Attach the image file here.
Consider parent/child relationships.
You do not want to select something before the child component.
