Why can't I shell this body?
My problem is can't shell my basic shape so I try to edit a sketch and Loft but can't fix it.
Could you give me a advice about this
my shapemy shape
thank you in advance
this is my file
etfrench
With multiple warnings and errors in the timeline, I'd recommend starting fresh.  Whenever you see a yellow warning or red error in the timeline, you should stop and fix them immediately.  They can lead to errors further down the timeline.
ETFrench
thank you for your advice I try to start with fresh and do without yellow and red warning on timeline but I Can't shell also(I can thicken but my purpose is adding some details on  solid face and then shell it )
Do you have any advice to fix this problem?
I just found  orange line on timeline bar what dose it mean?
thank you so much
etfrench
Moving the Timeline back to where the individual surfaces were created should allow you to use the Thicken command, however (  @jeff_strater  ), Fusion 360 hangs.
Note: @Anonymous The Thicken command should give you the same result as the Shell command for this model.
ETFrench
I need to make a details on it by extrude cut that why i don't use a thicken in and find the solution to shell it.Do you have any advice?
Thank you so much
TheCADWhisperer
I would look at this area first.
I would probably use "overbuild" surfaces and then trim back to avoid this "pinch".
