Why can't I insert an SVG?
lemelman
Message 1 of 12
lemelman
I must be dong something wrong, but what?
I open a sketch, select 'Insert SVG', choose the SVG from my computer, and it just disappears. What am I doing wrong please?
Replies (11)
Message 2 of 12
LeonardoBN
Isn't it in a big scale (not your SVG's fault, but the importing process)? Sometimes I have to scale down a lot to see the imported geometry.
Leonardo Brunelli do Nascimento
Chemical Engineer
Message 3 of 12
lemelman
The SVG is about A5 sized, so it's very comparable in size to the sketch.
Message 4 of 12
TheCADWhisperer
Attach the file here.
Message 5 of 12
lemelman
Here's the f3d, and the SVG.
Message 6 of 12
TheCADWhisperer
I am not sure how to get the svg file to appear, but in any case, my preference would be to place as a canvas image, scale and trace over.
Message 7 of 12
g-andresen
I have the impression that something is going wrong with the measurements.
In Fusion I measure 4695 mm after the import and in another application I measure about 177 mm. After the re-import in SVG it is 46.95 mm.
The attached file contains a re-import in DXF and measures 177 mm, just like before the re-import.
günther
Message 8 of 12
LeonardoBN
The original SVG is being imported really big.
Screencasts:
Only SVG: https://autode.sk/33Qbhd0
Your file: https://autode.sk/33Qbhd0
Chemical Engineer
Message 9 of 12
lemelman
Thanks to Leonardo's and Guenther's observations, it turns out that the SVG, which measures 182mm x 124mm in CorelDraw, is inserted some 250x larger. And not only that, the unwanted scaling doesn't include the line weight, so if I scale the SVG in Fusion, the lines become far too thin.
Is this a bug in Fusion, or is the SVG faulty in some way?
Message 10 of 12
g-andresen
I don't know of any vector graphics application that delivers the line width for a single line.
günther
Message 11 of 12
LeonardoBN
I don't know the correct terms, but the line thickness may not be exported directly to a SVG. It seems to be your case, where the 5 mm thickness are exported as "no thickness" lines.
There is an option in CorelDRAW:
1) Select your geometry and click Ungroup all Objects;
2) Object Menu / Convert Outline to Object (Ctrl+Shift+Q)
It will ungroup all lines and will convert your visible lines to a "real" geometry ready to be exported.
Here is the result in Fusion:
In this another example, i created two circles with different thickness (mm):
And the result in Fusion, applying or not that conversion:
Chemical Engineer
Message 12 of 12
lemelman
Thank you Leonardo,
That worked really well and totally solved my problem.
