05:00 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have an existing design with several bodies in it. Design history is turned off. When I attempt to delete a hole from one of the bodies, it just removes the surface and leaves an unstitched body.
However, if I copy the body and paste it into a new design (also with design history turned off), Fusion 360 removes the hole like I wanted to (and heals the surface through which the hole passes) when I delete the hole surface. Why the difference?
