Why can't I add a horizontal/vertical constraint?
rshouker
rshouker
I've sketched a ratchet, and I want to constrain the (originally horizontal) line segment to be horizontal. Fusion 360 refuses, but I don't really know why.
Video: http://autode.sk/29nNYJK
The design: http://a360.co/29AXzkc
Help please!
thanks,
Ronen
innovatenate
Autodesk Support
Autodesk Support
I was able to get it to work. Do you have sketch constraint status color preview enabled in the Preferences?
Here's a video recording:
I've attached the file for your reference. I hope that it helps!
Nathan Chandler
Principal Specialist
rshouker
I do have the sketch constraint status color preview enabled, disabling it seems to do the trick.
What does that have to do with failing to add the constraint?
Is that a bug?
innovatenate
Autodesk Support
Autodesk Support
We are still working out some kinks which is why the status color is in preview. I would say it looks like a bug to me. Sorry about the confusion! I will add this test case for our development team to review.
Thanks for reporting this!
Nathan Chandler
TheCADWhisperer
I recommend that you pattern features rather than sketch entities. (see attached)
rshouker
What are the merits of making the pattern in 3d rather than on 2d?
One thing I can think of is that you have a history line, which unfortunately is not supplied for 2d sketches.
Other pros?
