- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Please see the attached F3D file exported. It is for design of a GT2 pulley profile.
First see inside Sketch 4 (a new sketch), where the construction lines are inside Sketch 1.
Using the Point tool see the following areas and behavior of the program:
At the top of the circle construction shown here, you can see a box is created at the intersection of the circle and another line. This circle is Tangent to that line (and intersects it).
This square does NOT appear when attempting to hover over and create a point at the intersection shown here, where two circle constructions are Tangent to one another (and intersecting):
Now attempt the same inside Sketch 1: The Tangent constraints are clearly shown now (see symbol).
Intersection at top gets indicated as a square when attempting to place a point there as is expected.
Intersection between circles does not show the intersection when hovering over it.
