Which format should I choose for downloadable parts?
ecam6P6WJ
ecam6P6WJ
I am a 3D CAD beginner. I would like to start a design with some downloadable 3d parts. I can choose a lot of formats on the download. So I am not sure which format is the best to go with fusion 360.
As an example here is the link where I would like to download a few parts.
models ... on the right side you can find the download button there so many formats.
thanks a lot,
mathias
Beyondforce
Hi @ecam6P6WJ,
STEP or Inventor should work just fine. Notice when you are importing the model, it will be imported as a solide and you will be in Direct mode design.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
ecam6P6WJ
Can you explain that a little bit more... "it will be imported as a solide and you will be in Direct mode design".
Do you mean I can modify that? Can I look it anyway?
Beyondforce
Of course you can modify it. Actually Direct modeling is really good for modifying an imported components. But you can also use History Based modeling, depends on what kind of changes you want to make.
Here you go, watch this: http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2016/fusion-360/pd16277#chapter=0
Cheers / Ben.
Ben Korez
Facebook | YouTube
ecam6P6WJ
Many thanks for that video. I have learned a lot of stuff in this video I have never thought is possible.
cheers mathias
Beyondforce
Anything you need, just ask 🙂
Ben Korez
Facebook | YouTube
