I have just loaded a file I was working on yesterday and the history shows at the bottom but everything is greyed out other than the first sketch. I s that because I saved whilst editing the first sketch? Is there any way of restoring the history?
Solved by mail8YLTP. Go to Solution.
Solved by jhackney1972. Go to Solution.
Solved by g-andresen. Go to Solution.
Try dragging the timeline marker to the extreme right and see what you get.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
How did I miss that? 🙃 I tried clicking and double clicking the marker on the end and nothing happened so I assumed there was a problem. Bit unintuitive I think as there is no hint mind you I now know what >Right click>Roll the history marker here... means 😂 ... Dragging works fine thank you... 🙂
