Where are the text commands?
kshea9RNL8
kshea9RNL8
Hard for me to believe I have to ask for help to find the text commands but...............
Using "S" > Text and selected Text Command's
All this brings up is a full width partial window with a heading of "Text Command's" no commands anywhere.
g-andresen
Text command does only exist in sketch mode!
günther
jbarchuk
The one reply didn't answer the Q, which was the 'TEXT COMMANDS' box at the bottom of the screen under the timeline. If it's not visible, on PC ctrl-alt-c should make it appear. Also found under File - View.
My issue is that I have the box but don't know the magic key to enter text there.  Left click does nothing. Keystrokes return regular hotkey actions. Right-click gives me clear, copy, select all, not even a paste. I don't have a list of all keyboard commands so looking for that now.
jhackney1972
You are not quite down low enough.  The video will show you what you are missing.
John Hackney, Retired
jbarchuk
When you said not quite low enough I knew what happened, that there should be more stuff. I *thought* I had screen in full screen mode, but apparently not. When I did I still had to wrangle windows to get anything to happen. Probably years ago I glanced at the ctrl-alt-[letter] hotkeys to turn things on and off, but I *NEVER* used them because I've been using windows hotkeys for 30 years (c = cygwin) and wasn't about to change. I use Timeline very often so I would never be in the habit of turning that on/off anyway The rest of the text commands window was down there, fully opened, but Too Big for my screen! I got screencaps to show those but doesn't matter. Then I gave up and found out how to ctrl-r to reset everything. With that, there's the text entry box. Thanks much!
To answer the original Q, '?' returns a list of available commands, and 'command /?' returns more info.
The specific command that helped me is sketch.showunderconstrained. Perfect.
