Where are the Sketch Tools in the New UI?
Message 1 of 8
I have a very basic question. Where did the Sketch tools go?
I used the program today for the first time in ages. When I closed it and started it, everything was changed.
I opened a sketch I was working on. There are no tools for adding rectangles, circles, and so on.
I went to the 24 lessons for beginners, and the instructor was using the old UI, so no help. Where are the tools hiding? They appeared while I was trying to work on something, but then they vanished again, and after clicking everything on the screen, I have not found them.
Replies (7)
Message 2 of 8
Now the tools are popping up and disappearing. The toolbars keep changing without any kind of notice.
Another note: you should get real forum software.
Message 3 of 8
g-andresen
click here and sketch tools appear:
Sketch tools are only visible in the active sketch mode!
günther
Message 4 of 8
Thanks for the reply.
It looks like you have to load the sketch, click on the grid, and THEN click on the Sheet Metal icon.  When I click on the icon without clicking the grid first, nothing happens.
I don't know why they call it "Sheet Metal." Doesn't it just mean "2-D"?
Message 5 of 8
Well, I was wrong. I opened a new sketch, clicked the grid, clicked the icon, and nothing happened. I went through this process a second time, and then the tools appeared. I don't know if this PC is too slow for Fusion 360 or what.
Message 6 of 8
etfrench
To create a new sketch, just right click on any plane and select Create Sketch from the context menu.  There is no need to go the Sheet Metal tools.
To edit a sketch, right click on any geometry in the sketch or right click on the sketch in the Browser and select Edit Sketch.
ETFrench
Message 7 of 8
HughesTooling
This might help.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 8 of 8
g-andresen
Tips for using the toolbar.
Reset PanelReset Panel
The base position of the Sketch button is on the left!
günther
