When do you think it's appropriate to design several components within one assembly vs. design several different components as their own part files then assemble them into a separate assembly file.
MikeCroPhone
MikeCroPhone
Over the years, I've created many assembly projects that I've repeatedly revisited to create new iterations before reaching the "final" product. I've tried both methods of creating assemblies - creating them in one big assembly file, or creating them as separate "part files" which I then import into a separate "assembly file" (SolidWorks style).
I keep going back and forth between which method is better because they both have pros and cons and it annoys me that I haven't settled on one I like more than the other.  It bothers me that I don't have a clear blueprint of which one I should go with until I'm several iterations into the project, then I get frustrated that I didn't choose the other method as I'm meticulously changing details that affect the rest of the assembly. "This would have been easier if I started with the other method," I tell myself, then proceed to say the same thing about a different issue when I try the other method next time.
So, I'm curious what the community thinks: When you're designing assemblies, do you prefer creating all your parts in a single file and just adding components for each new part? Or do you prefer to tackle it SolidWorks style - creating brand-new files for each new part, then assembling them together in an assembly later?
davebYYPCU
I use hybrid, import existing (from McMaster etc,)
I can’t waste the time it takes for making new parts files.
one file per Assembly, is my go to.
Might help…..
jhackney1972
I use a hybrid of both methods.  I create sub-assemblies using components within the same assembly and save them out as external files.  Then when I create the final assembly I import the eternal sub-assemblies to finish off the model.  During my designing years we always shrived to have the top level assembly as clean as possible with the parts list only showing sub-assemblies.  We even went so far as to add fasteners to the sub-assemblies even if some looked a bit strange going through the holes in the sub-assembly and hanging out in mid-air.  When the drawings hit the manufacturing and assembly floor, they had everything per sub-assembly together.
Another thing is if you use cross-references between components in your design, creating these cross-references is a lot easier with the components local and not as inserted external files, at least in my opinion.
John Hackney, Retired
