What's the equivalent of the old Ground command
vcutajar
vcutajar
Hi
Previously when I wanted to do an assembly using various components, I used to use the Ground command on the first component and then add other components and join then together as I go.
Recently I needed to do a new assembly and noticed that instead of the old Ground command there are the Ground to Parent and also the Pin commands.
Is the Pin command a direct equivalent of the old Ground command?
Thanks in advance for any replies.
Vince
g-andresen
take a look  here
günther
vcutajar
Thanks for reply.
So Pin is the equivalent of the old Ground command.
I tried using the Ground to Parent but at times the grounded component used to move (most probably using it incorrectly).
In my case using Pin instead of Ground to Parent solved my problems.
Vince
