What's making this geometry overconstraind?
karl
Message 1 of 21
karl
In the attached file (and this screencast), I'd like to move the four holes and two cutouts (for a fan) .3" left to prevent the crash near the upper-right hole.  When I try to add a dimension between the left edge of the sketch and the center of the hole/cutout geometry, Fusion tells me the geometry is overconstrained.  I've tried fixing/unfixing the center point, but to no avail.  I can't see what else would be preventing this dimension.  Thanks for any tips.
Replies (20)
Message 2 of 21
billbedford
There is a locked sketch point at the centre of that square.
Message 3 of 21
TheCADWhisperer
I would significantly simplify this design, starting by breaking this up into at least 2 sketches, probably 3, maybe 4 sketches.
Use sketch points for hole locations and then place Hole Features.
Message 4 of 21
karl
I gather that the way to unlock a point is to delete the coincident constraint.  When I do this, though, I'm still unable to add a dimension to the left edge of the sketch, even if I delete the constrains five times.  In any event, I want those points to be coincident so all the geometry moves together.  Is there another way to unlock the point?
Message 5 of 21
karl
I'm happy to do that, but what's the advantage?  I'm still a newb, but when I was first starting out with Fusion I was criticized for breaking my designs into too many sketches.  What's the rule (or rule of thumb) for deciding when to "Finish Sketch?"
Also, how do I break up an existing sketch into multiple sketches?
I won't be extruding this sketch (except to get a sketch free of construction lines from which to make a DXF).  What's the advantage of using Hole Features over circles?
Message 6 of 21
TheCADWhisperer
@karl wrote:
...when I was first starting out with Fusion I was criticized for breaking my designs into too many sketches.
Do you have a link to that reference?
OK, in that case I would probably create the solid body (any thickness).
Project the face into a new sketch and Save as dxf the projected sketch...
Message 7 of 21
TheCADWhisperer
BTW - I saw several other "errors" in you sketch.
Message 8 of 21
karl
If you mean the criticism I mentioned, unfortunately it's buried in my post history.  It made sense at the time as my timeline was very long, so I thought a shorter timeline would be cleaner.  Maybe I'm overdoing it.  I've noticed that some operations (e.g. dimensioning) take several seconds to complete.  Would these speed up if I used more sketches?  I can imagine the calculations only being performed from the previous sketch instead of from the start of the timeline, which would make things faster, but, of course, that's just a guess as I have no idea what's going on under the hood.
> OK, in that case I would probably create the solid body (any thickness).  Project the face into a new sketch and Save as dxf the projected sketch...
Which is what I'm doing, so I guess I can skip Hole Features?
Message 9 of 21
karl
Please share.  You won't hurt my feelings.  😉  I'm here to learn.
Message 10 of 21
TheCADWhisperer
Examine the Attached example.
I keep each sketch relatively simple and easy to edit.
Another difference that I might make is to use a single datum (generally the Origin) for most if not all positioning dimensions.
Message 11 of 21
TheCADWhisperer
Missing Tangents on your slotted arcs.  In fact, if you use the sketch Slot command to create these - Fusion will do this for you.
Message 12 of 21
karl
Aah, thanks for pointing out that tool.  That'll save a ton of time in the future.
Message 13 of 21
karl
> Examine the Attached example...
Got it.  How'd you convert my single sketch into multiple sketches?
Message 14 of 21
TheCADWhisperer
I never trust someone else’s work- I started over from scratch.
Message 15 of 21
karl
Oh, jeez.  I'm embarrassed you invested the time, however short it might have been.  Thanks so much.  Still, is there a way to split up an existing sketch into multiple sketches, just in case someone didn't want to recreate everything (asking for a friend)?
Message 16 of 21
etfrench
There is no need to use a point there.  All of the circles or arcs have center points which can be used in the same manner as a single point.
I can't see any reason to make this into multiple sketches.  It just has a lot of holes and a couple of cutouts. Turning off the visibility of constraints and dimensions will make it less cluttered and show that it really isn't that complex.  There are quite a few extraneous construction lines which could be removed.  Note: Construction line end points will need to be dimensioned in order to fully dimension the sketch.
@jeff_strater: I can find no horizontal dimension or constraint for that geometry, so I would suspect file corruption or bug.
ETFrench
Message 17 of 21
karl
How do you do that?
Message 18 of 21
karl
Where?  I don’t know what you’re referring to, I’m afraid.
Message 19 of 21
TheCADWhisperer
Message 20 of 21
etfrench
I missed the locked point 😣 I'll change my assertion of a bug on a horizontal constraint to a UI bug on only exposing properties of geometry with color, especially on points.  One should be able to see the properties like X,Y, Z position, Fixed/Unfixed, constraints, etc. in a dialog.
ETFrench
