what is 'loop length' ?
Message 1 of 10
in Fusion 360 in "inspect => Measure => if I click on what I call a 'face' it gives me an area (that I can manually calculate and it "looks realistic" but it also offers me something called "Loop Length" - what is that?
Replies (9)
Message 2 of 10
macmanpb
The "Loop length" is the face outer contour length.
Message 3 of 10
THANK YOU (VERY MUCH) _ this 'seemed' to be the case, but manual calculations are a 'bit-off' (not surprise, it's early in the morning, here)- thank you FOR YOUR INPUT! - Bill
Message 4 of 10
TIMCOOKE6282
so, if I understand the solution correctly, for a circle profile, the loop length for a sector of the circle would be the arc length, the outer most contour of that sector of the profile
Message 5 of 10
TrippyLighting
Correct!
Message 6 of 10
TIMCOOKE6282
thank you sir
Message 7 of 10
navydoc.thomas67
Community Visitor
Community Visitor
Is that another way to say "circumference"?
Message 8 of 10
jhackney1972
Probably the best term to use is "perimeter" as the shape may not be circular in shape.
John Hackney, Retired
Message 9 of 10
navydoc.thomas67
Community Visitor
Community Visitor
thanks
Message 10 of 10
vertunc1976
The measure command under inspection menu lists two types of loop lenghts when I tyr to measure the distance between two construction planes. What are these loop lenghts?
