Hi there,
I just started to learn to use the fusion 360 ultimate and I am following the tutorial videos Autodesks posted on youtube. However, when I followed the tutorial and tried to add dimensions, Fusion prompted "Sketch geometryt is over constrained"
Attached is the screencast and note that the sketch dimension I try to add is the 59.402 one (the one vertically above the sketch).
Did I do something wrong?
In what conditions will a sketch geometry be over constrained ? Your help is much much much appreciated!
I also noticed that the tutorial on youtube is for Fusion 360 instead of Fusion 360 Ultimate, I wonder is there a big difference between these two softwares? There are something in the video that are not identical to the Fusion 360 Ultimate I am using, for example, there is no constraint menu in the drop-down list of SKETCH.
