What determines offset to be negative for unclosed lines?
samuelwhiskeyjohnsonaccount
In this example, the offset (red line) is negative and it's on the right of the original line (blue line)
But in this example, the offset is positive even though it is still at the right of the original line.
jhackney1972
The side that is a positive offset is normally determined by the direction of the original sketch line.  I cannot give you which direction is going to give you the positive offset for any line but you can see that the direction of sketch determines it.
By the way, yours is one of the longest Autodesk ID handles I have seen on the Forum.
John Hackney, Retired
jhackney1972
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
