Flange on cylinder surface based on intersection curve
kristian2TS4L
kristian2TS4L
I am creating a inlet to a barrel (cylinder) and want to add a flange to mount the tube inlet on the barrel surface with screw holes (width 20mm). I have created a intersection curve between the outer circle of the barrel and the inner circle of the tube as base for the flange, but I cannot create the flange based on this curve. I have tried to use the sweep command but it is not aligned with the cylinder as base. I also tried to make an offset curve of the intersection curve, but I cannot use this as base. Any ideas of how to make this?
Warmingup1953
HughesTooling
Here's one way. I modified the inlet extrusion to create a sold part, extracted a copy of the curved face then extended by 20mm.
Then thicken set to join.
Finally extrude the hole. See attached file.
Mark
Mark Hughes
Owner, Hughes Tooling
kristian2TS4L
kristian2TS4L
That is exactly what I was looking for. Thank You Mark for your great suggestion and precise response.
kristian2TS4L
It will be 3D print
