I am being asked if I had my question answered. I was being helped by James Youmatz, who is a very smart and helpful support person. He spent a lot of time on this. He did work out a process to solve my problem if it were not for the MOVE function. The MOVE point to point function does not let me click on the second point. It allows me to click on the first point, but forget about the second. It has problems. James seemed to have problems with it too. James suggested using Align, but that does not seem to work right for this application at least, either.
The idea is the take a mold, then place that mold where you want to make a cut-out. There are a few problems here.
1) How do I get the mold face perfectly parallel to the plate face that I am making a cut-out in.
There should be an simple automatic, click first side(on mold), click second side(on plate), push go. Done.
2) How do I know where I am at when moving the mold over the plate? In most other graphical interfaces you have coordinate readouts that change as you move an item over another item. This is a freebee in the Windows API. We did this kind of thing in basic C++ classes. Again, click on one Body side (not the middle), then click on the edge of the plate you are moving the mold over, then when the read-out says what you want, you go on from there with a cut-out.
I could even use the rulers, like in Photoshop or Illustrator, if I could get the Fusion 360 ruler to read out correctly and physically near the work I am dealing with. I have not seen a way to do that. Plus! Can somebody tell me who designed the rulers in 360? I am a programmer and have been since 1989 and I have never seen such buggyness before. It might just be that I don't know what I am doing. (That is always possible.) However, I am finding it impossible to get Inches with .5" per large scale, and 20 sub division happening here in FIXED mode. I mean, I get it into Inches, then select 20 division click OK and I am back in MM. Plus, the Ruler is miles away from the work. So, either I need a constant readout of the distance between edges of parts, or I need good working Rulers that are located nearby the work. I would then try to draw lines to create a cross-hair and move the mold to that point. I mean, it works in Photoshop and Illustrator.
So, I have made these points to James. I am still waiting for a response. He is a smart guy and very helpful. I am sure he or someone will chime in here. I want this program to work for me.
Again, I was asked to respond on if my problem was solved. Well, no. Not really. However, we have worked out a lot that approaches solving my problem.... It just has not yet.
CLMoss
