What are you running Fusion 360 on?
bryan5
bryan5
I am looking to get a new computer and I would like to have one that can run Fusion 360 with few hiccups.
With my current (old) computer I find Fusion 360 stalls a bit and becomes unresponsive.
Current computer specs:
Processor Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 3.40 GHz
Installed RAM 8.00 GB
System type 64-bit operating system, x64-based processor Edition
Windows 10 Home
Version 21H1
OS build 19043.1706
Experience Windows Feature Experience Pack 120.2212.4170.0
AMD RADEON HD 7500 SERIES
I am not looking to break the bank but would like something that can handle Fusion 360 and run smoothly. I plan mostly to use the CAD side for sheet metal design (models and assemblies), drawing for documentation, and CAM side for posting to waterjet, laser, plasma. From time to time some rendering.
Any suggestions are appreciated.
Thank you in advance
Bryan Lagrange
TrippyLighting
.Have you checked the resource monitor in Windows for memory utilization during those times when Fusion 360 seems to stall ?
8GB is not a lot for a computer running Fusion 360.
g-andresen
add another 8 GB bar in the first step
günther
Nilesh.Mohite
Hi @bryan5 ,
Here is the reference link to System requirements for Autodesk Fusion 360. https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Sys...
I hope this will help you to upgrade/choose your system to smoothly use  Fusion 360.
Nilesh Mohite
LinkedIn
If my answer helped you, please use  ACCEPT SOLUTION .
Also be generous with Likes!  Thank you and enjoy!
tommVS2MB
Don't break the bank. Use a free aws instance and pay only if you need more. Use that to guide you if you must purchase.
