Web feature creation issue
s_phamTESZU
s_phamTESZU
Hi Autodesk community,
I am trying to create a web structure within the curved shell, I create a sketch on the top surface of the round hole as instructed.
However, the web generated doesn't match to what I intended to build.
See the figure below:
The web passes through the internal wall and stops at the external wall. I’ve tried extruding the curved hole using both "New Body" and "Join", but the issue still persists. I also selected "To Next", but the extrusion doesn’t stop at the intended wall.
As an example, the figure below is what I would like to achieve instead:
Thank you.
jhackney1972
Please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it. If needed, ZIP a F3Z file.
John Hackney, Retired
s_phamTESZU
Hi John,
Thanks for replying, please see the attached model.
Sean
jhackney1972
This is probably not a job for the Web command.  I did one corner to show my method but there may be others.  I also did not know the width of the desire webs so I use 2mm.  I also did not know the angle of the one web so please check.
I attached my model but be careful as it is an F3Z file so if you Upload it to the same folder it will duplicate components.  I also had to ZIP the F3Z file as the Forum is not accepting this type of attachment from my end.
