Sketch extrusion issue
jasonalberts6
jasonalberts6
I'm just beginning to learn Fusion and can't figure out why my basic test extrusions appear as surface extrusions. Not solid bodies. Just the outline. Not filled in. Any help would be greatly appreciated. Here are a few things that I have verified so they can be ruled out-
1. The sketch is closed. The outline is black and the red lock symbol shows on the sketch in the browser window.
2. The extrude selection is being made from the Solid toolbar. Not from the Surface toolbar.
3. Profile is selected in the Sketch Palette.
4. Using Extrude, not thin Extrude
After ruling out all the above issues I closed and reopened fusion. Created new basic sketches. Just a circle, just a square. Same issue. Thanks again!
davebYYPCU
Looks like wireframe -
Check / change with the Visual Display settings, Menu at bottom of screen.
Might help...
jasonalberts6
You got it! Happened to figure this out this morning. This was the first of what will likely be many newb issues. I'll try to keep the posts to a minimum:) Thanks for the reply!
