Warning: The loft would flow in an invalid direction.
Naman__Dharmani
Naman__Dharmani
I'm trying to make the wing tip of an airplane wing, and when I try to loft this it says
Try adjusting the continuity settings. If two adjacent profiles are on the same plane, try moving one of these.
Autodesk Fusion 360 (Personal - Not for Commercial Use) 22_10_2022 22_03_18.pngAutodesk Fusion 360 (Personal - Not for Commercial Use) 22_10_2022 22_05_06.png
Naman__Dharmani
How do I go on solving this problem?
davebYYPCU
Need the file,
not enough construction, would expect top / bottom spar profile for a fighting chance.
separate at that profile for front and back halves.
Lofting to a point should be avoided, so looks like a front loft, then top and bottom rear Lofts.
3 in total.
Might help....
