Warning Review
Warning Review
Message 1 of 8
Warning Review
Hello everyone,
Oftentimes while designing some document I got some message about some minor warning in a pop-up window, placed in a bottom right area. This message quickly disappear leaving me wandering what went wrong. I have to repeat the last action, only because I want to read what's went wrong (I'm not native English speaking person and this tend to be very annoying). So, to sum things up: warning leaves no visible indication and therefore can't be accessed like an usual warning.
Can someone please how to access warning message or, at least, change a time during which this message is shown.
Than you in  advance.
Replies (7)
Message 2 of 8
Usually, the warning is still sitting there as yellow triangle with exclamation mark in the bottom-right corner. But sometimes this place is hidden by overlapped window (such as sketch constraints, for example).
Message 3 of 8
Thank you for your time. Sadly it's not reason I can assure you. I can't attach you screenshot (I'll try to catch it, but those situations are unpredictable). Those are a little errors, something with Fusion's inability to solve something but still gives some result, though not what I expect. As I said I'll try to take a screenshot.
Message 4 of 8
etfrench
Removing the reason for the error/warning will remove the error/warning icon. For example, if a shell command is not valid at 5mm but is valid at 6mm, then the error message will disappear when you're outside of the bounds.
Unfortunately, most of the error and warning messages don't contain meaningful information to the user.  At a minimum they should have a link that contains information on how to resolve the error.
ETFrench
Message 5 of 8
Well... the problem is that sometimes just happen that a message about some warning simply disappear. The problem is then - how to know what was written in the message - therefore my question was: where can I find something like log, to read last warning message. I know what to do when standard error or warning appears (although this can be really annoying - as you said - messages are often cryptic). Maybe it's solely problem with my particular installation? For some reason unique?
Message 6 of 8
HughesTooling
Can you make a screencast so we can see what you're seeing.
Download screencast here
https://knowledge.autodesk.com/community/screencast
Mark Hughes
Owner, Hughes Tooling
Message 7 of 8
I'll try it as soon as I can. Problem is that I'm simply not able to produce any such situation.
Message 8 of 8
One of the situation when error message slowly disappear (dimming like Outlook balloon message) is shown on a following link: https://knowledge.autodesk.com/community/screencast/a02c0273-706d-4b61-a89e-fcf1cec5a552. So, if you have a time...
