Warning - Edge Missing
Hi, I have a again a warning about a missing edge ( see my screenshot). The edge is displayed red, however, I cannot select the line to delete it. How can I resolve it ? I am bit lost and appreciate any help or hints how to deal with it. Cheers,
You have to work with yellow line (delete or break link). The red line just shows the original edge from which the yellow line was projected. If you close warning window the red line will disappear.
lure23
Essentially just needed to remove the yellow line, in my case. I hadn't managed to do it on my own because trying to delete just the end points does nothing. One needs to select the line itself, then delete, and this may be slightly difficult due to overlapping lines. Thanks. 🙂
Asko Kauppi
IT guy into Cleantech.
