wanted: script/addin for automated change of parameters and stl-export
picadilly
Message 1 of 13
picadilly
I would need a tool and I could image that others had the same need before me and maybe something exists already:
I do an open-source-project called osVAC neo. For details see: osvacneo.de
It is similiar to plumbing:
you have a few basic parts, like bows and T-connectors, but you need them in lots of different sizes and combinations thereof.
So, I did the designs und f360 and get the different sizes I change parameters.
To generate the stl-files I have to:
1) change the desired parameters
2) exports part(s) als stl (and step-files)
3) repeat the above for all desired combinations of parameters
Question:
Does anybody know a tool, which already does this or something similiar?
Replies (12)
Message 2 of 13
etfrench
There's a script in the store called ParameterIO that will export and import parameters.
ETFrench
Message 3 of 13
picadilly
Thanks, I will have a look at it.
Message 4 of 13
TrippyLighting
1. There is the Configurations functionality that will make this a lot easier.
2. There are at least 2 plugins that can make 23D printing easier.
https://forums.autodesk.com/t5/fusion-design-validate-document/3d-print-plus-and-3d-print-pro-extend...
https://github.com/WilkoV/Fusion360_ExportIt
https://forums.autodesk.com/t5/fusion-design-validate-document/new-add-in-to-export-stl-step-and-f3d...
Message 5 of 13
picadilly
What is the "Configurations functionality" about? Maybe something, which is not included in the free version?
Message 6 of 13
picadilly
I forgot to add:
thanks for your reply. I should have written that in the first place:-)
I will have a look for the other links, you posted.
Message 7 of 13
TrippyLighting
Unfortunately it isn't included in the free subscriptions 😕
Here is a link to the documentation.
Message 8 of 13
picadilly
A good friend created the attached piece of code for me. I got that to work. I will try to work from there, but I hoped somebody would have done more work prior to me:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, os, traceback
def get_immediate_children(component😞
    # Get the child occurrences (components) directly under the specified component
    child_occurrences = component.occurrences
    # Extract the actual component objects from the occurrences
    child_components = [occ.component for occ in child_occurrences if occ.isVisible]
    return child_components
def set_parameter(app, design, parameterName, parameterValue😞
    ui = app.userInterface
    userParameters = design.userParameters
    userParameter = userParameters.itemByName(parameterName)
    if userParameter:
        userParameter.expression = str(parameterValue)
    else:
        ui.messageBox('User-Parameter "{}" nicht gefunden.'.format(parameterName), 'Fehler')
        return
    # update parametric text plugin
    app.fireCustomEvent('thomasa88_ParametricText_Ext_Update')
    adsk.doEvents()
    adsk.doEvents()
def export_stl(exportMgr, body, parameterValue😞
    # Dateinamen aus dem Körpernamen ableiten
    fileName = os.path.join("D:\\tmp", body.name + '_' + str(parameterValue) + '.stl')
    stlOptions = exportMgr.createSTLExportOptions(body, fileName)
    stlOptions.sendToPrintUtility = False # Setze auf True, wenn du die Exportdatei direkt drucken möchtest
    # Körper als STL exportieren
    exportMgr.execute(stlOptions)
def run(context😞
    ui = None
    try:
        # Zugriff auf Fusion 360 UI
        app = adsk.core.Application.get()
        # Dokument und Design erhalten
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        if not design:
            ui.messageBox('Kein aktives Fusion 360 Design.', 'Fehler')
            return
        # Get the root component
        root_component = design.rootComponent
        # Get the immediate child components under the root component
        immediate_children = get_immediate_children(root_component)
        # User-Parameter ändern
        parameterName = 'HoseDiameterInner'  # Name des zu ändernden Parameters
        for parameterValue in range(30, 50, 5😞
            set_parameter(app, design, parameterName, parameterValue)
            # Export
            exportMgr = design.exportManager
            for component in immediate_children:
                export_stl(exportMgr, component, parameterValue)
        ui.messageBox('Export erfolgreich abgeschlossen.')
    except:
        if ui:
            ui.messageBox('Fehler aufgetreten:\n{}'.format(traceback.format_exc()))
Message 9 of 13
TrippyLighting
If you want to post code and need help with it:
1. There is a Fusion API Forum section where this gets better feedback
2. Place your code in code tags:
Message 10 of 13
andrew_tchircoff
@picadilly this is probably way to late but I've made as script that does something like that: https://forums.autodesk.com/t5/fusion-api-and-scripts-forum/batch-exporter-script-for-different-para...
Message 11 of 13
picadilly
Cool. I wrote a reply at the link, you mentioned.
Message 12 of 13
TimelesslyTiredYouth
none of my business but figured I should just point it out when I noticed it.
I noticed that the code loops over the whole component rather than bodies, and there's a chance it may fail in the case scenario where it's made of multiple bodies.
and reuse objects – like exportMgr and userParameters, instead of recreating them each iteration, saves repeated calls to the API.
Hope it help,
Ricky
Message 13 of 13
picadilly
I have not looked at it yet. But as I did something similiar:
In my case, I export components. Exporting all bodies separately is not what I need - at least most of the time.
