Hello @karanbskd
I do not know this methodology to work inside Fusion 360. You may have to check some of the other FEA programs to see if it is possible.
I found a tutorial that indicates some steps for these result you can access it here:
https://www.javelin-tech.com/blog/2011/05/using-deformed-fea-model/
I believe these steps can help you in your work, good luck!
Did you find this answer helpful? If so, please use the Accept as Solution or Kudos button below.
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
