wall mount
wall mount
wall mount
wall mountwall mount
hello fusion 360 forum
thank you any and all input and suggestions.
i'm trying to model this wall mount and i'm stymied.
the circular base is 54.61 mm with a thickness of 3.175mm.
the 3 flanges are 19.05 mm tall and wide with a thickness of 2.54 mm.
I don't know what tools to use to get a finished product similar to the
included graphic.
please advice. Again, thank you for all suggestions.
micheal
docara
Welcome to the forum.
Right, the basic procedure is you draw a 'Sketch' then extrude enclosed profile. You can only draw a Sketch on a face or a plane. So when you start the 'Create Sketch' command you will be presented with 3 planes - just choose one.
The information you have included is not enough to reproduce what you want accurately. What is the spacings between the prongs, what is the angle of the prongs?
You NEED to hit some tutorials so you know how Fusion operates and what terms to use if and when you need to search for a solution to a problem or ask for help.
Matt
melvinbrian3d
@Anonymousas @docara told you, there is not enough information to reproduce exactly this part
MelvinBrian3D
Thank you for your feedback.
Michael
davebYYPCU
Can get this far, with the detail you supplied, sure I did it the easiest way with your dimensions.  More details, more accuracy.
Might help...
