Voronoi Pattern on a Dome / Sphere
certified_mad
Observer Observer
certified_mad
Observer
Observer
Hi All
I could do with your help please, I am trying to recreate the following example:
I am current using the free Voronoi Sketch Generator to create the pattern, but I have been unable to create the same pattern on a dome as above it maybe not possible using the Voronoi Sketch Generator?
I could do with some tips possible methods I could model the features or If anyone as a suitable example of something very similar that could be adapted for my needs.
Thanks in advances for your support.
mavigogun
From the little study I've done, the application's output is flat.   If you don't care about cell density distribution, you could Project the pattern to the surface of a dome, then hope a Press Pull would execute successfully.   Manually, you could 3D sketch a network of Lines around a dome, Project to Surface, create Patch Surfaces from them, Thicken those surfaces, then apply Fillets to the junctions, then Intersect the result with a Shelled dome.   I suppose what you do depends, in part,  on how much you want it.
jodom4
Hey certified_mad,
You could make short work of that with Dynamo: https://apps.autodesk.com/FUSION/en/Detail/Index?id=74731490955641349&appLang=en&os=Win64
[video]
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
TrippyLighting
Yes, but Windows only (Yuck!) and :
joestolars
Thread resurrection. I saw some of this type of design and I could not remember what the technique is. Thought it was something new. It is very interesting. Thought that this is what Generative design is. Mistaken, but happy to have found a thread on here, quite by accident.
