Voronoi installation
Message 1 of 21
I get problems on mac trying to install the voronoi plugin.
If I install the plugin it says installed succes (I downloaded it from the site and double clicked on it as i install all my programs)
When i open fusion 360, it is not listed under the scripts and add-ins, in the add-in tab.
Also i can't find it back in the menu (sketch, create, modify,...)
Do i have to install it on an other way or did i missed something, only found information to stop and uninstall the plugin but nothing to install.
Thanks for helping
Replies (20)
Message 2 of 21
LMD001
@Anonymous
If you open the Scripts and Add Ins:
Screen Shot 2017-02-28 at 14.00.29.pngScreen Shot 2017-02-28 at 13.59.25.png
You should find the Voronoi in the Add Ins tab.
If you open the pkg file hold CTRL and click it to open the security settings.
Hope is of any help to you,
Best regards,
Ludo
Message 3 of 21
Hello Ludo,
Thanks for trying to help me.
When I try to install the add-in it say it is successfully installed (see screenshot)
When i open fusion 360 and check add-ins it isn't listed. I downloaded the add-in from the autodesk app store.
(https://apps.autodesk.com/FUSION/en/Detail/Index?id=1006119760063675415&os=Mac&appLang=en)
I also tried to remove fusion 360 and installed again from the App Store en directly from autodesk (without App Store in case the add-in woud install in different location in the libraries folder, cause these 2 have different folders) but none of them work.
In neither of both locations i can find back any installation files of the voronoi bundle:
  • Mac OS (web install):
    • Script: ~/Library/Application Support/Autodesk/Autodesk Fusion 360/API/Scripts
    • Add-In: ~/Library/Application Support/Autodesk/Autodesk Fusion 360/API/AddIns
  • Mac OS (Mac App Store [MAS]):
    • Script: ~/Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application Support/Autodesk/Autodesk Fusion 360/API/Scripts
    • Add-In: ~/Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application Support/Autodesk/Autodesk Fusion 360/API/AddIns
Message 4 of 21
LMD001
@Anonymous
Hello Roeland,
Just downloaded the Voronoi Sketch Generator again and installed it with no problem, not sure what's going on here.
For now do not know if I can help you with this but will check further.
Best,
Ludo
Message 5 of 21
LMD001
@Anonymous
This is what I did:
1) Downloaded the Voronoi Sketch Generator from the Fusion 360 App Store (same as you apparently): https://apps.autodesk.com/FUSION/en/Detail/Index?id=1006119760063675415&appLang=en&os=Mac
2) CTRL-click (to open the security dialog) this pkg file and confirm that it is OK to open the file.
3) Follow the installation instructions, provide password when needed.
4) Restart Fusion 360.
After installation the Voronoi Sketch Generator appears in the Create menu.
So, again, not sure why this does not work on your side.
Best regards,
Ludo
Message 6 of 21
LMD001
@Anonymous
Tried the VSG in both Timeline and Direct modelling and it seems to work fine.
Also noticed that you run a Dutch OS, I have English OS on my computer, could it be that this causes the problem?
Best,
Ludo
Message 7 of 21
I Just did the exact same steps, It's not installed.
I tried it on my older macbook and there it worked, the only bad thing about that is that it is getting to old to run it smooth 😞
So Strange it works on one and not on the other.
Message 8 of 21
Ok this is strange my old macbook is installed in English OS and it succeed, my new one is indeed in dutch OS could that really be the problem?
Message 9 of 21
LMD001
@Anonymous
Hi, not sure here but it seems that the language locale somehow interferes, maybe the writer of the Voronoi Sketch Generator add in @hanskellner could shine some light on this.
Best regards,
Ludo
Message 10 of 21
hanskellner
Doing a little research on this.  Will report back when I learn more.
Hans Kellner
Senior Manager, Principal Engineer
Message 11 of 21
adam.nagy
Autodesk Support
Autodesk Support
Hi Roeland,
Do other Fusion App Store add-ins work fine on the problem machine?
Do both machines have Fusion installed from the Mac App Store?
Cheers,
Adam Nagy
Autodesk Platform Services
Message 12 of 21
First on the new machine it was installed from the App Store, but to try i deleted it and installed directly from autodesk, that doesn't work either.
On the old macbook was directly installed from autodesk, didn't tested it from the App Store.
On the new macbook i have slicer installed for fusion 360 and i installed that separately.
Message 13 of 21
Hello Everyone,
I got a Skype call with adam.nagy and he helped me out. Then reason the plugin didn't install is probably because I have a Dutch OS.
Adam did sent me the voronoi.bundle and we did put the voronoi.bundle manually in the following folder:
 /Bibliotheek/Application Support/Autodesk/ApplicationPlugins/
(Bibliotheek is the library folder in dutch)
I've added the voronoi.bundle in attachment if anyone would have the same problem.
Seems like this problem also apply to other plugins, only slicer did install correctly.
Special thanks to Adam.nagy to help me out and sent me the voronoi.bundle! 🙂
Message 14 of 21
LMD001
@Anonymous
Good to read you are up and running !
This is an example why I always install English OS.
Best regards,
Ludo
Message 15 of 21
Bonjour
J'ai le même problème, avez vous eu une solution?
merci à vous
Message 16 of 21
adam.nagy
Autodesk Support
Autodesk Support
If you have the same problem then the above solution (copying the bundle that @Anonymous attached to the correct folder) should be a solution for you.
Adam Nagy
Message 17 of 21
Hi guys, having the same problem with dutch OS but I can't find the folder  /Bibliotheek/Application Support/Autodesk/ApplicationPlugins/ on my system. I've searched all folders but no luck. Creating this folder doesn't do the trick either so where to put the files?
Message 18 of 21
Idem, toujours pas de solution...
Message 19 of 21
adam.nagy
Autodesk Support
Autodesk Support
This should provide a workaround:
http://modthemachine.typepad.com/my_weblog/2018/04/the-installation-failed-for-app-store-plug-ins.ht...
Adam Nagy
Message 20 of 21
bataman
Community Visitor
Community Visitor
Hi I am having this problem you had. I have a mac and sec settings don't come up when I control click.do you have any other suggestions
