VisualStyles cloud preferences not created
matthewsclark
matthewsclark
Hi, I get the message you can see on the attached screenshot every time I launch Fusion since the last update. I click yes every time, but I can’t find the Visual Style drop down menu referred to in the dialog box tip.
There is Visual Styles setup in the Display Settings menu, which include a checkbox for Local Preferences, which is unchecked.
Am I missing something or is this a bug?
Thanks, Matt
innovatenate
Autodesk Support
Autodesk Support
I'm wondering if executing the clear user cache data command located in the help menu might help resolve this error message. This will reset the current preferences and toolbars, but it might resolve this error message.
The only Visual Styles setting I can think of at the moment is the one on the navigation bar, but I'm not sure this error message is related.
I hope that suggestion helps. Please let me know either way! I'm happy to keep digging.
Nathan Chandler
Principal Specialist
daniel_lyall
@innovatenate it will be the plugin VisualStyles https://apps.autodesk.com/FUSION/en/Detail/Index?id=170904292335894747&appLang=en&os=Mac
@matthewsclark goto the post here and ask http://forums.autodesk.com/t5/api-and-scripts/my-first-add-in-visual-styles/m-p/6701822
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
matthewsclark
Thanks, I re-posted in the plugin thread.
msheridan523
Not sure if you figured this one out yet but basically you have to check the "Local Preferences" box under the Display Settings > Visiual Style Setup. This is the menu at the bottom of the screen next to the visual style buttons. After checking that box the error goes away. Visual Styles.jpg
