Vision Impaired settings question.
kshea9RNL8
kshea9RNL8
With in the Fusion 360 CAD UI are there font settings I am overlooking?
The fonts are too light, and a bit too small, forum text here can be adjusted in size acceptably with windows settings but even it is too light, not enough contrast.
Ken
rishivadher
Hi Ken
Unfortunately is the only configuration that exists
kshea9RNL8
Thanks Rishi.
mjames
If you are on a Windows machine, go to the Control Panel and the Fonts thingy. You can adjust the general font size to from 100% to 125% and 150%. Fusion will use this new setting, as well as most other applications.
There must be something similar on a Mac, but I have no recent experience with them.
kshea9RNL8
I've had my system set at 125%, It does help, 150% is even better for me but Fusion 360 will then not let you close the Data Panel at 150%, at least on my system using Windows 7 Home Pro, don't know using Win 7 Pro.
