Visibility issue in animation workspace
I would just like to say thanks initally for your time. I am new to the software and forum so am unsure whether this post is in the right category / on the right page so apologies if it is not.
I am attempting to create an animation showing various components of a design. I have set up all the necessary show/hide keyframes so objects should be visible however I am facing this issue where there is only a basic outline and some bad shading with no textures so it is impossible to see the product and therefore publish the video.
This issue I am having seems to be extremly inconsistent, sometimes showing textures and other times not. I have tried to mess with the settings and make sure it is not disabling the textures for performance reasons however I may have got this wrong.
The screengrab attached shows objects that are supposedly (as far as I can tell) enabled to be visible. I have also included a screengrab of the model so you can compare what it should look like.
Any help is appreicated,
Jon
whittakerdw
Are all of the components activated in the drawing that is shaded? The radio button beside the very top component should be activated. Like so
Hi, Thanks for the response. Since posting the question the issue appeared to fix itself so I am assuming it was some kind of bug. I simply changed from the animation workspace to the model workspace and I could then see the objects.
Many Thanks
whittakerdw
Glad to hear its fixed
