View stuck on hidden edges
Jacy7896
Message 1 of 11
Jacy7896
Just update fusion and since have had my visual style stuck on seeing the hidden edges of my model. Also the grid is massive now.
How do i change my visual style back? I've tried the setting but no luck, maybe I'm doing it wrong.
Replies (10)
Message 2 of 11
g-andresen
check your display and grid settings
günther
Message 3 of 11
TheCADWhisperer
@Jacy7896
Message 4 of 11
Jacy7896
Opened another model I have and the settings are the same, but this model is still showing me hidden edges with a massive grid.
Message 5 of 11
Jacy7896
I've been able to stop the showing of hidden edges by going back a couple of steps to a dodgy extrude. However, my grid for this model is still massive.
Message 6 of 11
Jacy7896
Here it is, only facing the grid issue now
Message 7 of 11
Jacy7896
Somehow figured out how to fix it all, thank you both for replying though 😄
(Fixing the dodgy extrude fixed it)
Message 8 of 11
jhackney1972
Certainly not much of a solution description.  You need to attach the model and show what you did as the "solution" so others can avoid your issue.
John Hackney, Retired
Message 9 of 11
TheCADWhisperer
@Jacy7896
First thing I noticed is that many of your sketches were not fully defined.
Sketch1 has some "funny" dimensions?
I saw unresolved issues highlighted in your Timeline (Ctrl b or CMD b).
Message 10 of 11
Jacy7896
The last step I did before the visual style setting got stuck was negatively extruding an aspect of a body which had uneven geometry. I don't know why that caused the issue, I just know that going back before I did it and then negatively extruding a different way stopped it.
Message 11 of 11
Jacy7896
Thank you TheCADWhisperer, I'm aware of the "funny" dimensions and the unresolved issues, however, they were not the issue for this specific problem it seems.
Thank you for your time nontheless.
