View / Clear render queue
letterle
letterle
Hi Everyone
Is it possible to view and or clear the render queue?
I've started a set of renders about 10 hours ago and nothing is happening. I've cleared all the renders and restarted them but still no change.
There may be something running that I don't know about.
Thanks!!!
JamieGilchrist
hi letterle,
I've forwarded this on to our development team to take a look.  Will follow up in a bit.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
letterle
https://a360.co/2wN4eoy
This seems to be the file that's not working properly. I'm unable to delete the rendering in the queue, as well as the file itself. I figure this is preventing other renderings from loading. When I try to copy the file and delete the old one. It states 'this document is in use it cannot be deleted'. "In the details page, it states it is not used by any other files.
Can someone remotely clear the queue???
Thanks!!!
Roy
anavaidya
Hi Roy,
You rendering seems to be stuck and does not even begin.
Thanks for sharing your file. We will take a look  to see if it's a file issue or a problem with the service, and get back to you. Thanks for your patience.
-Aradhana
Aradhana Vaidya
Customer Success Engineer, Rendering & Visualization
anavaidya
Hi @letterle
We found an internal issue with the Rendering service which was causing your file to remain stuck in the queue. We have released a fix. Please try rendering again. It should work. Let us know, if you see any further issues.
Aradhana Vaidya
