Variable thickness boat propeller
I am trying to create a boat propeller with variable thickness. The blade is thicker near the center and gets thinner near the edge. I can create the blade using a coils, extracting curves, creating a surface using the loft command then thinken that surface. However that body has a constant thickness. Any thoughts on creating a variable thickness blade? Thanks
SaeedHamza
Could you please attach a picture of what you mean
Regards, Saeed
Saeed Hamza
Just posted a picture
venkitr
Face draft might achieve the result
Rajesh.V
Fusion 360 Developer
Link Name | Link Name | Link Name | Link Name
