Variable Pitch Sprin / Progressive Helix / Equation Support
marvinzapf
marvinzapf
Hey,
I want to create a helix with a progressive pitch!
Since I am a Mac user, I can't use Inventor to do it, nor use a Plugin which unfortunately are only available for Windows.
This feature was requested for years now. I know because I looked at every single "solution" that was posted since Fusion 360 emerged.
I even started requesting it in your surveys, where I was supposed to get an amazon coupon. But neither did I get a voucher nor the feature itself.
Can somebody please tell me, if you are working on such a feature and when we actually can expect the implementation of it.
Equation Support would immediately fix so many of the the workarounds we need to use to get our job done in Fusion.
MichaelT_123
Hi, Mr MarvinZapf,
You must be desperate... over two weeks you re-posted your grievances three times (1+3 altogether).
Are you familiar with the thread?
https://forums.autodesk.com/t5/fusion-360-design-validate/variable-pitch-thread-helix/m-p/8494822
If yes, what would be your spring definition as the equation (close to 'banana')?
Regards
MichaelT
MichaelT
