Variable Fillet Edge
boyleiste
boyleiste
Hi everyone!
I'm trying to make the edge of knife handle project exactly as on the photo but I couldn't handle it. Fillet or chamfer doesn't work since the edges have too sharp curves. If you have any suggestions I would be very appreciated.
TrippyLighting
The area you have highlighted is NOT a fillet. It is created by one, or more lofts between two profiles.
It would probably have been better if you continued to post it in your other thread.
Attached is a model with what  believe you are looking for. before continuing to model I would remove the small decorative fillets at the end of the timeline and then add any other necessary details.
Also, it was not my goal to create a final model, but rather to demonstrate techniques that can get you there.
boyleiste
Dear Peter,
I have opened a new thread because of the misundertanding on the other one but thank you for your caution. I also learn forum's rules and manners.
The solution was beyond helpful. Thank you very much!
Best regards,
Sabah Petek
