Using Sweep to create groove inside irregular solid
sjj530
sjj530
I have an irregular shape made up of separate elements - eventually these will be separate components.  I've defined a offset plane using "plane along path" and used that to sketch a rectangular profile at a right angle to the surface of one element.  I want to use Sweep to cut away that profile all around the interior.  However, Sweep won't allow me to select all the edges to form the path.    I only seem to be able to select one edge for the path.rabbet.JPG
Essentially, I want to cut a recess (I think technically it is called a rabbet) on the bottom, on the inside of this open shape.  Any suggestions?   Thanks!
g-andresen
simply project the contour into a new sketch (path)
Screencast
jeff_strater
you need to hold down CTRL (CMD on Mac) to be able to add to the path.  So:  activate the Path input, hold down CTRL, and you can add more edges to the path:
Jeff Strater
Engineering Director
rushabhthakkar_910
Click Ctrl Key, And select each Path Line..!!
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
sjj530
Thanks! That fixed it.  For some reason I was having trouble selecting the edges I wanted, to form the path in sweep, but projecting the edges onto a new path in a new sketch was the right answer
sjj530
Thanks for all the replies!  For some reason, using the CTRL key to add additional segments to the path did not work.  Don't know if it was a glitch in my keyboard, in F360, or what, but Sweep just wouldn't let me add additional edges.   Projecting those edges onto a path in a new sketch, before I opened Sweep, did work.      Thanks again!
