Using Sheet Metal tool with V-Grooves
knightblde
Message 1 of 12
knightblde
Hi,  I make a lot of parts using foam or ACM.  Just imagine a simple U-channel 2" wide with 1" returns from 1/8" material.  I don't cold bend it.  I v-groove on the bend lines and only have about .020" in material for the bend with almost no radius to it.  The bend makes a nice miter that is almost invisible.
Is there a way to model this in Fusion so that I can get the proper cut lines and 3D model for proofing?
Thanks!
I found this video on YouTube which is similar.
Replies (11)
Message 2 of 12
lichtzeichenanlage
I'm not an expert. But did you try to setup a k0 material and to use the flat pattern for your carving process?
Edit: In addition you might want to change the bending properties in the setup, too.
Message 3 of 12
g-andresen
look at this
günther
Message 4 of 12
TheCADWhisperer
I think the OP is looking for functionality similar to this bend.
Message 5 of 12
lichtzeichenanlage
Have you watched his video?
Message 6 of 12
TheCADWhisperer
Are you referring to the router carving?
I don't think Fusion is going to automatically return the Design Intent.
I should have pointed out that my original attachment illustrated a Fail as indicated by the red highlight in the timeline.
Message 7 of 12
knightblde
V Groove - .015" reliefV Groove - .015" reliefFolded 1Folded 1Folded 2Folded 2
Above is a typical example.  There is a VERY small amount of material left before the fold.  usually .010" - .020".  There is basically no radius, none that we care to calculate, that's for sure.  These are super easy and require little work or help from Fusion 360.  But the project below is MUCH more complicated and Fusion 360 could help a lot with it.
BearBear
If nothing like it exists, what would you call it so I can add it to the suggestion queue?
Thanks!
Message 8 of 12
TheCADWhisperer
I think you could model as paper-thin material to get flat pattern and use the Bend Lines for creating the router tool path, but you will not be able to model real thickness with real groove cuts.  So you will have to be careful to allow appropriate clearances.
I am not familiar with other software tools that might have this functionality, so i cannot make a recommendation on other tools.
I would try a simple box first and see if you can work up a technique.
Message 9 of 12
knightblde
Yeah, the devil is in the thickness.  When we do 1/2" foam core, the bend is actually paper thin, but it takes up 1/2" space.
Thanks for looking at it.  If you think of anything I'm all eyes!
Message 10 of 12
laughingcreek
fusion sheet metal might have a harder time with some of the more complicated model, like that polar bear.
pepakura is a paper craft program that I've adapted to do all sorts of cool stuff.  for the price, it is amazingly functional.
https://www.tamasoft.co.jp/pepakura-en/
Message 11 of 12
adam7QKMK
Did you come to a conclusion with a technique for modeling bent ACM, after all?
Message 12 of 12
knightblde
Sorry it took so long to see this.  No, not really.  What I have done is use a very thin sheet and offset it the thickness of my material.  Not the best set up, but puts the outside of my bends in the correct location.
